What are your thoughts about the following ST tires. Hercules load range D Task Master load range D Carlisle RH load range D Tow Master load range E Omni load range E I am looking to replace...
Also check the rating on your RIMS. Usually stamped on rear, or in valley under the tire. Fully inflating a LR-D on a LR-C rim is as THIRTY PERCENT OVERLOAD!!!! Obviously LR-E is even worse.
