jeepman71
Jul 23, 2013Explorer
Which tires
What are your thoughts about the following ST tires. Hercules load range D Task Master load range D Carlisle RH load range D Tow Master load range E Omni load range E I am looking to replace...
Omni load range E
I am looking to replace the tires on my 2013 Rockwood fifth wheel that had load range C.
Thanks
How many miles do you tow a year? I wouldn't spend the money for Maxxis if you only go out a few times a year and don't travel very far. If you go out a lot and put a lot of miles a year on then yes Maxxis. ST tires are generally only good for 5-7 yrs depending on what site you read. So if you only put 4-500 miles a year on them then I would look at Goodyear Marathons. Upgrading to a larger higher capacity tire will help you. Most tire issues are from under inflation, heat, driving to fast and overloading.
