jeepman71
Jul 23, 2013Explorer
Which tires
What are your thoughts about the following ST tires. Hercules load range D Task Master load range D Carlisle RH load range D Tow Master load range E Omni load range E I am looking to replace...
jeepman71 wrote:
I am going to guess the rims are only rated for 2150 each and with the smallish bolt pattern I am sure a 16" wheel is out of the question. At this point I am not looking to replace the wheels, I like the looks and don't want to spend the money. I would think that upgrading the tires to a load range D and running at 60 psi would make a huge improvement on the tire blowup problem. At 60 psi with a load range D my capacity improves by 230# per tire. I know the wheel is still an LR C.
