jdeputy1's avatar
jdeputy1
Which truck?
Hi everybody,
I am looking to retire in a few years and will be in the market for a fifth wheel. The floor plan that we are looking at is around 41feet long with a GVWR of 20,000 lbs. I am thinking that a properly equipped one ton dually will do the trick. My question is:
Long bed vs Short bed, what are the advantages or disadvantages of each.
Thank you for your input.
  • IMO, if you need a DRW truck, to tow a large FW, you also need a long bed. You are likely going to carry more things with, after retiring, and going longer distances. More bed space is good, and the truck will be big either way. You will have more hitch options, not having to worry about a slider, although the rounded front of most new FWs has made that less of an issue. The longer bed will work better with add on equipment like tool boxes, or fuel tanks.
    Be sure to get the FW prep option (puck system).
    Welcome to the forum!
    Jerry
  • Try a search.
    Use current 12 months - and "archives" - threads over 12 months old.
    Gazillion threads -and replies - (or at least ten, ROTFL) with the same question.
