Chris Bryant wrote:
You can probably calibrate the thermostat- I don’t have anything on the furion, but most oven thermostats you can pull the knob off and there is an adjustable set screw in the center of the shaft- I turn it on, set to 300, let it stabilize temperature, see what the temp actually is, then I hold the set screw stationary and turn the shaft to approximately the correct position, then turn the temp up and see how close it is.
IMHO, this should be a warranty item, Furion might disagree.
I did call them but they will closed so they actually have not even turned me down yet !
