RustyJC
Apr 20, 2017Explorer
Searching_Ut wrote:
Have a 2015 SRW Ram, AISIN tranny. For towing a 5er configured as my generally is at just under 15k it does good, really comfortable seats and ride that work for long towing days up to a thousand miles. Quite reasonable fuel economy for a 1-ton.
You're hearing all sorts of pluses, so I'll list a few of what I consider to be faults:
Brake controller doesn't give full braking at slower speed and may or may not give full braking to trailer in a panic stop even at high speed. If you have the center console installing a controller that works is difficult due to space constraints.
Auto rear air suspension and snowy/cold weather don't get along well. Most noticeable if you tow in the cold/snow where it's common to get a "Service Air Suspension" light when you start up after having been parked for a bit. The fixes they've come up with so far for the issue help but don't fix it.
AISIN transmission far more prone to hunting than the Chrysler variants. You end up having to manually select your gearing most of the time when towing.
As mentioned by others, steering is typical Ram somewhat vague feeling setup. Not bad really, but nowhere near as nice as the steering in comparable Chevy trucks for instance. These trucks are definitely freeway cruisers and not for running empty on winding mountain roads.
The factory integrated trailer brake controller works great with the electric over hydraulic disc brakes on our 19,000 lb GVWR Mobile Suites when set to Electric over Hydraulic, Heavy at a gain of 5.5.
Your "hunting" complaint regarding the Aisin transmission is probably more related to the 3.42 rear axle ratio in your SRW truck than the transmission itself. With the 4.10 axle ratio, I've yet to have to select gears manually to compensate for transmission hunting.
The steering isn't as good as my previous 2WD 2011 Ram 3500 dually which had independent front suspension with rack and pinion steering, but it's livable. I suspect it's a consequence of the recirculating ball steering box and solid front axle used on the Ram 4x4s. Of course, with the newer 4th generation chassis, 4x2 or 4x4 is irrelevant since the 4x2 trucks now use a solid front axle as well.
Rusty
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
