rhagfo
May 03, 2016Explorer III
Chuck .. wrote:
Want are the big advantages of the 5th wheel compared to a tow trailer?
Here is want I have below but, I still wished I could pull more safety, like a used 30 foot Dream Suit 5th wheel or a Alpenlite unit that weights around 11,500 dry weight.
I have a 1999 Dodge diesel 2500, Long bed, auto trans, cub cab, 2 wheel drive. The owner manual on page 148 says that this truck can tow maximum trailer weight of 10,200 with 3.54 axle ratio and 12,000 lbs maximum trailer with 4.10 axle ratio. The GCWR is 16,000.
Most everyone on this forum and others said I can only haul a trailer around 9,000 lbs. "Dry Weight" safety and do not max out my truck! I plan on being safe.
Well a couple questions on the TV 99 2500 Ram.
What is your gear ratio?
Is the 5.9 chipped at all?
Is the Transmission Stock?
I pull/carry a 2005 Copper Canyon 293 FWSLS with our 2001 2500 Camper Special Ram, we do it, but not a recommendation as you will well over GVWR! While with 2 WD, you gain a bit of payload over us.
Specs on the 5er.
Dry weight 9,820#
GVWR 12,360#
current towed weight about 11,000#
TV
GVWR 8,800#
GFAWR 5,200
GRAWR 6,084
Loaded TV
GFAW 4,500#
GRAW 5,500
GVW 10,000#
5er axles 9,500#
GCVW 19,500#
We run a small 50 hp and about 130 lb.ft. chip, and a 5 speed manual with a Double Disk clutch.
I do feel that I could pull/carry the full GVWR of the 5er!
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
