Me_Again
Sep 27, 2013Explorer III
schlep1967 wrote:Most manufactures that have RK models build them on the same frame as their RL models. Floor space in a RK model is more or less single use while the floor space in the mid kitchen is multi use. Most small to mid size RK models have a crummy TV viewing situation for two or more people.
Simple answer is, it is cheaper to put everything in the middle. Shorter plumbing runs on both supply and return lines. Shorter gas and electric lines. Weight over the axels means less support needed for the rear of the trailer.
We like our larger rear window with two recliners that look straight at the TV.
Chris
About Fifth Wheel Group
