albow's avatar
albow
Why do they put seam tape on slide roofs instead of caulking
The top of slides is the only place I've seen it. I wonder why they use it there instead of caulking? My only guess is the friction between the slideout rubber and the caulk may cause the caulk not to take. Wait, I just thought of something else. Maybe when the slide is in, the rubber and the caulk don't jive well or it tries to rub it off then or when virating going up and down the road. Anybody know?
  • But, caulk seems to be used on the sides of the slide where the tape ends. Maybe because it's vertical at that point for some reason?
  • Community Alumni's avatar
    Community Alumni
    On my trailer there isn't any tape on the slides, only caulk. But the flap is only a weather seal to keep out rain or snow. It is not the seal to keep cold or heat in or out. So, when the slides are out the flap is 2-3 inches away from the caulk at the inner seam of the rubber roof and rests on the rubber roof material. When the slides are in the flap passes over the caulk on the outer edge of the roof material and rests on a metal edge of the slide wall. The caulk has never been effected by the flap. And when we set up camp I check the flaps to be sure they are flipped outward and if not I use the awning pull rod to pull them out, Takes about a minute for 3 slides.
  • Previous rig had Eternabond over the joint where the slide wall met the rubber. Never had a problem with the seals NOT flipping. Seems to help them flip.Not so with current rig.
  • Did you ever see a perfectly flat and even bead of caulk? The seal has to seal against it and tape is flat smooth and level. If the top of the slide is..
