motorcycle_jack
Jun 11, 2013Explorer II
The placement of the items inside has very little to do with the pin weight. It is where the balance point versus the axle placement that effects it most. If you have a problem with understanding that, let me give you an example. Lets say the given 5th wheel has a total weight of 10K and the pin weight is 2K (20% of total weight). Now add 1K to the rear of the unit. Does that mean the pin weight is now 1K? Since you added it behind the axle (which is not the balance point). No. The total weight is 11K (10 + 1) and the pin weight is now 20% x 11K or 2200 lbs. Sorry, just the nature of the design.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
