TenOC's avatar
TenOC
Nomad
Jul 08, 2017
Why tow level ??? -- Is it important -- How to acheive
I am not talking about when the TV is nose high and the front wheels are floating off the pavement.
In a few weeks, I am going to move from a TT to a 5er. With a TT it is a simple mater to adjust the hitch ball to tow level. With a 5er I understand the need to maintain 6 inches clearances between the TV bed rails and the 5er so the trailer does not hit the TV bed rails. I understand that all 5er hitches have a way to adjust the hitch height.
The only way I know to adjust a nose-high 5er (and maintain the 6" bed rail clearing) is to adjust (raise) the suspension (flip axles etc) of the 5er or lower the TV suspension.
I have not done the math because it depends on the length and weight of the 5er, but a quick estimate is that by towing nose-high by a foot only transfers about 100 lbs from the pin to the wheels.
So inquiring minds want to know how important is towing lever?. . . :h. . . . What am I overlooking?
  • You would never know the rear RV axle has 1,400# more scale weight than the front axle by this pic. It really does matter to tow as level as possible.
  • The biggest thing about a level trailer when towing is keeping the trailers leaf spring suspension level. Some mistakenly think the trailer suspension equalizer bar evens the load which it doesn't 100 percent.
    Most equipment trailer mfg keep the deck level with the bottom of the frame at the forward and aft spring hanger mounts. This way when dot weighs us we know the trailers axles/tires are carrying equal loads.
    A nose high trailer can place more load on the trailers last axle....and take weight from the front axle. This can cause the front axle(s) brakes to flat spot the tires.
    Also the trailer axle suspension works best when level.
    Triaxle trailers need closer attention to being level when on the road.
    And of course we know a nose high or low condition can cause chunking issues with the tow vehicle.
    Torsion axles ??
    Non of my rv trailers have never had them and I wouldn't have them on any of my work trailers. Others may have some experience with them.
    Pin/GN ball weight changes little to non with a out of level trailer....at least on my flatdeck trailers when loading and weighing for a balanced load. I doubt rv trailers are different
    Jim
  • JIMNLIN wrote:
    IMO your over thinking a problem that doesn't exist.
    You say...."but a quick estimate is that by towing nose-high by a foot only transfers about 100 lbs from the pin to the wheels".
    What wheels are you referring to ?
    The 5er wheels.
  • IMO your over thinking a problem that doesn't exist.
  • You could be overloading the rear axle and tires is the main reason.
    Changed (are to could be). No way to know for sure without scales. Some axles and tires are marginal to begin with.
