carringb
May 30, 2013Explorer
Weekend Warrior 32'+ (FS3000, FS3400, FSC/FSW3200) pull-behing models might be able to depending on dry weight. The ramp doors are strong enough, and they did not list a cargo area restriction. But the dry weights can be so heavy a Jeep would probably end most over the 13000 GVWR. I don't recommend exceeding the GVWR, even if there is lots of axle capacity left. Turns out the frame is the weak point. A aluminum-body WW might be light enough to stay under GVWR loaded with a jeep.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
