garyp4951
Sep 19, 2019Explorer III
Kootenayguy wrote:
Hi. This question applies to anyone with a 2008 or newer Canadian built Citation Supreme or Corsair Excella 5th wheel. These units have a rounded front and not a flat front. I have a Dodge Ram with a 6'4" box and a B & W Companion fixed (not slider) 5th wheel hitch mounted in the usual position between the wheel wells. Will the front of one of these 5th wheels hit the rear window of the truck on a hard turn? I'm thinking because of the rounded front of the 5th wheel I may be safe. Thanks
I believe B&W shows 3" back, with the truck attachment in position 2, to be the farthest you can go, and should give you a little over 40" from the cab.
You will still have to be careful backing, but many people use this setup.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
