laknox
Sep 19, 2019Nomad
Kootenayguy wrote:
Hi. This question applies to anyone with a 2008 or newer Canadian built Citation Supreme or Corsair Excella 5th wheel. These units have a rounded front and not a flat front. I have a Dodge Ram with a 6'4" box and a B & W Companion fixed (not slider) 5th wheel hitch mounted in the usual position between the wheel wells. Will the front of one of these 5th wheels hit the rear window of the truck on a hard turn? I'm thinking because of the rounded front of the 5th wheel I may be safe. Thanks
Simple answer; ALL will hit when backing up...at some point. SOME will hit going forward. A slider will almost always keep you from hitting going forward and give you more room before you WILL hit in reverse.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
