JIMNLIN
Sep 20, 2019Explorer III
op wrote:
I have a Dodge Ram with a 6'4" box and a B & W Companion fixed (not slider) 5th wheel hitch mounted in the usual position between the wheel wells. Will the front of one of these 5th wheels hit the rear window of the truck on a hard turn? I'm thinking because of the rounded front of the 5th wheel I may be safe. Thanks
Lots of histeria about short bed cab/5er corner contact when it fact its rare....but it can happen.
We've had new members on various rv websites before ask will my 5er contact my GM short bed truck. They got the usual gotta' have a slider from many who had no idea but read some where you gotta' have a slider. Anywayz some bought the more expensive Superglide auto slider. After a year or so of camping with other short bed GM owners that had no sliding hitch they questioned their choice. Some kept them and others sold them and went with a lighter hitch with much less maintenance. My sons '18 short bed chevy crew cab and a 5er with rounded corners which has 5"-7" of clearance at the shortest point in a turn on any angle.
No one can tell you if your combo will contact. I would try the std hitch first and if it comes 2"-3" at the closest point while backing then I would be interested in some type of sliding hitch or different pin box like the Reese Sidewinder.
GM has the longest C/A (cab to axle) dimension at
..41.26"....
Ford at 39."....
Dodge/Ram at 37.4".
Use what you have and if it doesn't work ...then spend your bucks on one that works best.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
