JRscooby
Sep 21, 2019Explorer II
Two Hands wrote:
I think I would certainly find out. Go out into a large parking lot and slowly start making tighter and tighter turns while keeping a close eye on the front cap of your fifth wheel. You will then know for sure.
IMHO, a much better plan would be use a tape measure, get the distance back of cab to center of 5th wheel. Next, measure width of cab at the height of nose of trailer. Now a piece of string, tie a loop large enough to fit around the king-pin in the end. Pull the loop straight, and measure the first measurement down the string, and put a clip on the string. Put loop around king-pin, with string in front of trailer, then move to side until clip gets to front of trailer, make a mark. Measure from that mark, back toward center half the width of cab, that is where it will contact.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
