Lantley
Sep 21, 2019Nomad
JRscooby wrote:Two Hands wrote:
I think I would certainly find out. Go out into a large parking lot and slowly start making tighter and tighter turns while keeping a close eye on the front cap of your fifth wheel. You will then know for sure.
IMHO, a much better plan would be use a tape measure, get the distance back of cab to center of 5th wheel. Next, measure width of cab at the height of nose of trailer. Now a piece of string, tie a loop large enough to fit around the king-pin in the end. Pull the loop straight, and measure the first measurement down the string, and put a clip on the string. Put loop around king-pin, with string in front of trailer, then move to side until clip gets to front of trailer, make a mark. Measure from that mark, back toward center half the width of cab, that is where it will contact.
Then hope you always camp on flat ground where the trailer or truck will not tilt or pitch
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
