gtsum
May 10, 2014Explorer
Went to dealer the other day and the owner moved some rigs around and put his hitch in my bed and had me back under a eagle ht. my truck maybe squatted an inch....not much at all. I had enough bed rail clearance but it was a bit nose high. I then backed under a grand designs 4 slide unit that had a dry weight of 12k. Truck squatted maybe 2-3 inches, had about 7 inches clearance on the bed rail and was about perfectly level. Obviously the higher pin weight and 16 inch tires helped out. Not sure what we r going to do. The axles r already flipped on the jayco and u cannot put 16 inch tires on it per jayco.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
