Bobz89013
May 25, 2018Explorer
Traveling Teechers wrote:
I'm all for replacing myself I do it all myself...my problem is the frame of the screen has a rubber edge that does not sit flush with the window so it's like a leaking gasket that is letting bugs in. Harvester Ants are swarming where I'm at and its really uncomfortable. It's really sad that my only solution seems to be contacting a custom window shop. There is little industry for such common problems in RV. Everything is expensive. Thanks.
You can pick up the entire kit at any hardware store to make a new screen frame and all. It is done with straight cuts and put together with the supplied corners. Like I said above I used a shade cloth to help block the sun or you can use regular screen.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
