Rabiesbabies's avatar
Rabiesbabies
Winter camping help
Hello everyone, i'm very new to camping. Pretty much just want a toy hauler for the winter. But need help with some questions. I go out west snowmobiling in the winter,and I'm looking to get get a toy hauler so I can just pack up and go when I please. To my understanding I should find one with a winter package. But seems hard to find one I like used. Is it even possible to go out in the winter if I do not have one with a winter package? Also any other advice would help being I've never even been camping before. Thanks!
  • I camp all the time in winter here in Norther Ontario and although a battle hardly the end of the world or even close to impossible.
    I camp with the system in full operation in a rig barely 3 season campable by KZ. It does have a decently insulated and coroplast covered belly, with all walls and floors being about R7.
    I have electrically heated pads on all the tanks and heat trace on the interior water lines.
    Heat is mostly provided by three ceramic cube heaters doing "zone" heating with the propane furnace doing all the grunt work to get the rig up to temp and maintain it should the temps drop more than what the electric heaters can maintain(I have camped as low as -30C/-22F)
    In so far as dumping the tanks I do that at home with a Flojet macerator. Don't need a clean out, just a convenient toilet if that is all that is available.
    Lot's of other tricks to keep the cold out and the heat in from Relectix in the windows, carpets on the floor, heated mattress pads and so on. Also having at least a 3kw generator with you as well should power fail due to storms, which up North in my neck of the woods happens quite often.
    It's not impossible, just challenging.
  • In Northern Michigan, most of my camping is during the winter, COLD winter.
    Keeping your plumbing systems operational is a battle, but the bigger battle, is what to do with the holding tanks when it's time to dump them.
    Cleanout at home? Nope, buried under 4-5ft of snow. Cleanout at a rest area? Nope, gated off until June. Cleanout at the RV park, gated off and buried under 4-5ft of snow.
    Just something to think about.
    For me, I try to heat with gasoline when possible, it's cheaper than propane and much easier to find refills. When I'm alone in a rustic campground, or just setup in the woods, the generator runs non stop.
  • DutchmenSport wrote:
    Yes, you can successfully camp in winter-snowy weather in an RV, but in order to ensure your water lines do not freeze, the water system needs to be winterized. This is by far the safest way to ensure old man winter doesn't damage your system.
    Then, you use water, very much like you would if you were tent camping. No running water inside the camper. Absolutely no water down the drains. Absolutely do not use the toilet. Why? Because water freezes, and then pipes break and valves burst.
    If winter camper, we bring water with us, separate, in containers. (I now have a 35 gallon tank we use). Water is never flushed down the toilet. We use a port-a-potty and dump in in campground outhouses. We do not use chemicals in the port-a-potty, but we do dump it and rinse it every day.
    We heat water on the stove, take cat-baths, and catch any water in the sink in a tub in the sink and then toss it out the door. (like brushing teeth, sponge bath, etc.)
    Being in the Army a few years we had to learn to live with water only from a canteen and enough water to fill our helmets for bathing, brushing teeth, and anything else for personal hygiene. The advantage of an RV? You can heat the water on the stove first!
    Cooking? Gas stove? Dishes? Wash in a tub and dump it outside or in a pit toilet, just like you would if you tent camped.
    This is really the only sure-fire way to make sure no water freezes in your camper. 4 season campers means very little. If you are camping off the power grid, you need heated tanks, that takes power, LOTS of battery power. 4 season means the air ducts for the furnace run under the floor and along the water pipes, and that's all. There are reports of pipes freezing inside the coach, under cabinets, and right above the floor. Your best approach is to use the camper with absolutely no water in the tanks or the water system, just as if you were in a tent. This is how we do it. It works well for us, but ours is usually just a week-end jaunt. State Parks in Indiana have power at the campsites all year round. But after October 31, the water is shut off. So, no bath houses, no water at the dump stations, and those state parks with water at the sites, are turned off also. Bring it in, take it out! For us, this works.
    X2
    Buy a case of the cheap RV antifreeze at Wallys and use that to flush the turlet when needed. You can at least dump the pink stink out. It sucks taking a shower with it though.
  • Yes, you can successfully camp in winter-snowy weather in an RV, but in order to ensure your water lines do not freeze, the water system needs to be winterized. This is by far the safest way to ensure old man winter doesn't damage your system.
  • Have a good source of propane because you're gonna burn a bunch of it. We've camped in below freezing conditions and these trailers aren't insulated all that well even though they claim to be four seasons.
