RideSlow's avatar
RideSlow
Winter Heat
In our TH, if I am on shore power, when I turn on the heat, the A/C fan comes on. It is loud, and since we do not have a heat strip, it blows cold air. I understand the concept, but it is not comfortable at the volume level. The fan runs, even when the furnace is at rest.
I do have a small electric heater for the bedroom at night.
Options are a fan switch to slow down the A/C fan, or a cutout to disable it.
Or I find an indoor propane heater, which seems redundant.
Thoughts or suggestions welcomed.
  • You should have three settings on thermostat, "Low - High - Auto". If it is in either the Low or High setting the A/C fan will run whenever the furnace is on. In the auto setting the A/C fan will not turn on with the furnace. Hope this helps.....
  • Sorry, I guess I wasn't clear, the A/C is recirculating the interior air. The compressor is not running. Although I have available a lo fan setting, it is only available in the 'fan' setting. The main issue for us is the noise of that thing.
  • old guy wrote:
    sounds like your thermostat is wired wrong.
    Or you haven't changed the thermostat settings from AC to heat.
