Dick_B wrote:
X2 on Dutchman Sport. If you let all the water out of the FW tank the pump can lose its prime which happened the first time I winterized. Pump the pink stuff than open the drain lines. Don't forget to bypass the water heater or you will use lots of pink stuff.
Hmmm...you may be on to something. We camped this past weekend and I knew we were running low on fresh water. I didnt realize until I went to open the drain to completely empty it that we HAD run out. Only got a gallon or two out of the tank.
So, assuming it had lost its prime, should I have put some water back into the FW tank to get it primed up again before trying to winterize?
