Dan50
Oct 27, 2016Explorer
Winterizing problem.
When I was winterizing my Big Country today I did the usual, turn the Anderson valve to winterize and flip the red handle of the hot water heater bypass to bypass the hot water tank. Put my hose into the antifreeze jug and turned on the pump. Antifreeze flowed through the faucets
etc. with no problem but when I turned off the faucets I noticed the pump cycling about every 5 seconds. Was wondering what was going on. Went back outside to check the jug and after listening to the pump short cycle for a bit I saw antifreeze start to drip out of the hot water heater. Stopped wen I turned the pup off. I'm thinking that the red handled bypass valve is defective and is letting antifreeze through to the tank. No leak behind the udc. Worked fine last year when winterizing Does that sound reasonable or could it be something else ? Thanks in advance.
