Artum_Snowbird
Dec 03, 2017Explorer
Never put antifreeze into your fresh water tank or your hot water tank. It's just not the right thing to do.
If there is not a bypass at the water pump so you can put a short hose into a gallon of antifreeze, there should be.
Your water tank should be drained. If you can drive around with your fresh tank drain valve open, it does get out the very last bits.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
