NMDriver
Dec 03, 2017Explorer
Regardless of how you get the pink in the line, drain/blow it out and after adding some to the p-traps, save it for next year.
I blow out my lines then add the pink to my fresh tank-about 8 gallons- and get 8 gallons back out by opening the fresh tank drain and blowing out lines to the low point bib. I only loose the little bit that goes into the P traps. My 5er does not have a by-pass or easy access to the pump so this works best for me.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
