Thanks :-) The Fuzion is equipped with the Jensen In-Command system, which has all the switches on the tablet control panel...touch screen. It turns on lights, water heater, water pump, operates slide outs, awnings, etc. I mentioned to the dealer when we bought it, that I was a bit concerned about SO much technology and if it fails we are SOL! When I "turn on" the water pump via the In-Command touch screen and open a faucet...nothing happens. No water pump noise...nothing. There is no manual switch that we can find to bypass the stupid In-Command tablet, so I will be calling the dealer today to see if we can't get this figured out.
