To answer your question, winterizing the dishwasher, refrigerator, and washer is pretty easy. When you put the waterbay knobs in winterize mode, and suck the a/f in, run washer on cold until you see pink, then cancel, and let washer drain, then repeat on hot. Dishwasher, same, start a cycle until you see pink, cancel and drain. Ice maker takes longer, have to let the machine run a few ice cycles until you see pink.
Don't forget to bypass the waterheater, and drain that too.
Personally, I'd bring the rig home, plug it in, run heat at 50 for the couple days.
