rhagfo
Jul 07, 2017Explorer III
Your 5er is the correct size to run LT truck tires. 235/85-16 will have 3,042# of capacity, more than the total GVWR of your 5er. Running the "G" rated at the max 110# psi, will beat your 5er to death. Not only that if you are running a 110# psi then they are grossly over inflated, giving you far less braking traction.
Sorry, I feel you over reacted to the blowout and put way too much tire on your 5er.
About Fifth Wheel Group
