laknox's avatar
laknox
Nomad
Aug 17, 2021
Tires...I know, tired subject
So, coming home from our recent boondocker, I decided to stop about 40 miles in to grab some food. My habit when I stop, is to walk around and look at, and feel, all my tires and hubs. I noticed that the RR trailer tire was significantly hotter than the other three. Made me stop and look at it more closely and I saw that the tread was rounded across the tire, instead of flat. So, tread's separating, but it's a "symmetric" failure, all around the tire. Rather than risk another nearly 100 miles, I changed the tire. DOT date of 2616 on all 5 tires, so > 5 years old. Now, my rig's placarded for D tires, which really are plenty of tire for a 10.5k GVW rig, given that an 8-ply D tire is 2540 lbs capacity, so over 10k lbs total. I'd probably hold my nose and buy Endurance (not a GY fan), but they don't make them in a D range in this size, at least that I can find. I did run a couple sets of the newer Carlisles on my old Komfort, but they were E rated. I liked them and had no issues with them. Almost always run at 70 psi instead of 80. Are there any decent D rated tires out there? Usual 225/75-R15 size. Should I just save some money and go with E rated Carlisles again, since I'd probably only run them at 65 or 70 psi? Should I bite the bullet and go to 16" wheels/tires? There are just so many more options with 16".
Lyle
