d-mac1
Jul 26, 2014Explorer
Would you run either of these tires?
The first one is my spare. I've got 3 other tires that are similar. The issue is a wave in the sidewall that is usually just in one place on each tire, but if its present, its on both the inside sidewall and the outside sidewall. . These are Towmaster tires and they've been like that since the trailer was new.
I stood the tire on a board so you could hopefully see the wave by the letter T.
The one below is my right front. I just had my axles straightened and am contemplating junking this tire...or using it as a spare. Naturally, it doesn't have a wavy sidewall, but took the brunt of the alignment issue on the outside edge. Would you run it?
Thanks!
Thanks!
Here-You can have this BFG Commercial TA and 2 more that did not explode but do have broken belts. All at the same time on my trailer. Dealer says manufacturing defect-BFG said sorry-you have them on tralier service. My truck had BFG Commercial T/A's and were recalled. Had lots of problems getting them replaced. Called BFG and they were no help-wouldn't even call the dealer.
