bkirkpatrick wrote:
Follow the wire and see where it goes. If it ends up connecting to the frame somewhere, then I don't think it is positive. However, the red color tape on the ends would be a very good indicator that it is in fact a positive wire. You said that you already put in on the positive... well what happened? Also a pic would help.
nothing happened best I can tell.
I reconnected it to ground terminal and had a great trip to Indy 500 (other than getting stuck in the Coke lot on Monday). I was able to watch TV Sunday night with battery power only. I plugged in the "quick charge" connector and drove it home on Monday (15 hour drive) and the batteries were charged to "good".
I had my RV mechanic look at it before I left and he said that all white wires are usually grounds. This means I have two hooked up as ground and gang of positives.
I have no way to trace it unless I unbundled the harness. I do have a volt meter but need some advice how to check it in this instance. Thought some one with a WW trailer could tell me.
