alarmin wrote:
Camorhino, the o-ring is part of the check valve inside the city water connection.
Old-Biscuit, I had also thought about using a PVC plug, but it has to be air tight to keep my pump from cycling. I'm sure I can get it to work but will save that as a last resort. By the way, my wife almost s**t herself when I told her WW is back.
Vulcanmars, I like this idea. Would something like this work? What did you use?
Yes, very similar. I got mine from the local big box store. My lines were easy to access as my connections are very close to the sink. It looks like Shark Bite makes a check valve that should be a breeze to install.
Fittings
