I also have recall items needing repair. I have an '05 FS 2600 with alluminum sides and have noticed the compartment door located at the front left side of my trailer won't close shut unless it is slammed shut or unless I lift on the bottom portion to twist the door into place. I also have some roof separation located also at the front of the trailer on the same side as the compartment door. The trim that runs along the roof line has separated. I called WW last week and I was told someone from Warrior would call me to address any recall items I have pending. I called again this week and was told to wait yet again for someone to call me regarding any recall repairs I required. I mentioned I also require their prophylactic fix which caused the frame twisting which caused my roof and compartment door to flex. Has anyone else experienced the same service as I?
Thank you.
