dedmiston
Dec 12, 2007Moderator
WW Repairs
As just about all of us have read here, certain models of WW trailers have defects that have resulted in a number of different problems. To one degree or another, this subject has come up on this for...
pcassidy111 wrote:dedmiston wrote:pcassidy111 wrote:
I talked to WW a couple of days ago about my 05 FS 2600 and they said it was not included in the recall for the prophylatic fix, only the 01 and 02's.
Not true. My '05 FS2600 was covered.
Have you had the prophylactic fix done to your trailer yet? If so what did they do. Who did you talk to at WW and did you give them your vin number? It is my understanding that it is only the trailers that have their tongue formed by the bending together of the 2 pieces of C channel that run the length of the trailer are in need of the fix. According to the diagram of the fix 2 pieces of C channel are welded in between the point of the bend for the tongue and the front of the trailer and the joint is reinforced with a gusset. On my trailer (date of manufacture 04/04) I have 2 pieces of 6 inch C channel that run from the front to the back of the trailer. The tongue is formed with 2 separate pieces of 6 inch C channel. The geometry of my frame is identical to what the fix accomplishes, less the gussets. Are trailers with my frame geometry getting the gussets welding on to them? I gave WW my vin number and they told me it was not elegible for the fix.
I wrote:
The biggest part of the fix was the new A-Frame. The old setup had the two legs of the "A" attached a few (maybe five?) feet behind the front of the box of the trailer. The front of the box provided the cross member for the "A". The new "A" is totally different. Picture an A, but instead of a line connecting the two legs of the A, there's a box enclosing the ends of the legs of the A, continuing around (and outside) the legs of the A, and crossing through the middle of the A. It's lots beefier.
I don't know if this is a generic fix or if this was the solution for mine. All I know is that it appears to have fixed what was wrong with mine. They finished the work on time and they didn't charge me for the repairs.
