dedmiston
Dec 12, 2007Moderator
WW Repairs
As just about all of us have read here, certain models of WW trailers have defects that have resulted in a number of different problems. To one degree or another, this subject has come up on this for...
allcool wrote:Wizbangdoodle wrote:
I have an '07 full throttle 5er. I have been busy with repairs on this rig. I was sitting here browsing and came upon this thread. Am I to assume that since this is a sticky, that WW's have an unusually high amount of problems. I don't doubt it. This thing has more problems than I care to remember. I am in the middle of repairing the garage wall from water intrusion from the wheel well. The entire lower wall was rotten. I cut a piece of treated 2x12 to fit in the space, coated it with flexseal and wrapped it in Tyvex. Once that was bolted in, I resealed the side to the board. Used expanding foam where needed and under-coated the whole thing with flexseal. Pain in the ass for something that should have been sealed at the factory.
Let me guess,,, the wheel well separated from the wall and floor. Textbook WW(and many other TH) wall sag symptom.
Just fixing the symptom will not fix your problem.
It will only get much worse, more costly to fix.
Do a search for WW wall sag. Its a frame problem.
If one wheel well was already leaking enough to cause water damage, you've probably got it bad.
jmo
