dedmiston
Dec 12, 2007Moderator
WW Repairs
As just about all of us have read here, certain models of WW trailers have defects that have resulted in a number of different problems. To one degree or another, this subject has come up on this for...
Wizbangdoodle wrote:SolidAxleDurango wrote:Wizbangdoodle wrote:
Great info. I'll have to try that test. Mine is a bit different though being that it is a 5th wheel, the garage is separate from the living area. I suppose I should be able to put my hand on the front wall of the garage and see if there is any flex. As I understood it, the Full Throttles did not suffer from frame issues like the tongue trailers did. Anyone have confirmation on this? Anyway, I have not really seen any evidence of trim misalignment or seams coming apart. I pray I don't have any frame issues or I may have to drive this thing off a cliff. Oh well, taking it to an alignment shop on Monday to get all 3 axles straight. The tires on the rear axle always wear out premature. Left side wears on the inside, right side wears on the outside. Other 2 axles seem to be ok. I was told they use cheap Chinese axles on these. I am also having brake issues with this unit. I tow with an '08 F-350 with a built-in brake controller. I'll be driving along and it will display "wiring fault on trailer". I replaced the pigtail and the plug in the bed of the truck, still has the problem. I disconnected 1 set of brakes at a time and it went away. I assume there is an intermittent short on the coils. Anyone have suggestions of a reliable brand brake replacement?
Mine was a 5th wheel....
Ugh, I didn't want to hear that. So, did this test work for you? You had wall separation?
