allcool
Jan 15, 2014Explorer
WW toilet water valve question.
Anyone know what valve I should order for my 2007 WW fsw 3200 for a direct replacement..?
The existing toilet has the little spray handle mounted up on the wall behind the toilet coming from the valve.
I am 2500 miles away from it so don't know what toilet/valve is in there now. Had a small leak from the valve last trip and forgot to get the info off the toilet/valve. And would like to bring the correct replacement valve out with me next trip.
Has anyone else had a problem with the existing water tube feeding the toilet valve coming out of that ? soffit ? or whatever that wall board box behind the toilet is ?
Mine has about 1" of exposed tubing coming out of that box at an angle, bent with a crimp in it...? I will probably have to open up that soffit and replace that tubing and add a shut off valve.
And help would be much appreciated, thanks...
