DynoDragn's avatar
DynoDragn
XLR Nitro first week experience and couple questions
Well I have had my TH for a week and so far it's been pretty awesome. I've had the shower drain issue but not too bad.
However after playing with every little gadget I've found a couple things not working. My CD/DVD player is the car style but it won't take any CD all the way in. Just runs in about 90% and stops. Not sure what's up with that. And the other thing (most important) is my rear stabilizers are electric like a scissor jack. I ran it down until it almost touched the pads and I reach under and leveled them and when I hit the button again it won't work up or down. Any thoughts?
I'm going out tomorrow and play with it some more as I might have a bad connection.
Due to my sewer being 30' from the drain I elected to hook up a power sewer pump that has a garden hose outlet. Because I am 75ft away from the park toilets I haven't had any solid waste use but I've been told that pump does a good job and I don't have to have the 3" sewer line. I did have to run a 12v 10ga power source out to it.
  • I had to fix a water leak by the fresh water pump under the sink and have noticed that when they cut the walls to pass piping through they really butcher it. I mean the holes are like wolverine opened them. I know they are hidden but dang. And being I have 2 grey tanks my capacity is really half as one is for my bathroom and the other the kitchen. I never hardly use the kitchen sink but take showers a lot.
    My black tank is massive and I've been really good at just number 1s only as the camp bathroom is across from me but one night at Taco Bell.. Didn't think I would make it.
    I'll be running some piping from the sink to the garage to make a washer dryer hookup so I can put a stackable in the garage. It is only 110v on the gas dryer. I figure being in the campground for awhile I might rent a 100lb tank to sit beside my tongue so I don't have to refill as much.
  • Slow drain? I found if I'm not perfectly level it drains better. If I'm up a tad up in the front / half a bubble off. Same is true for the black tank.
