ol_Bombero-JC
Aug 03, 2017Explorer
MFL wrote:
You mentioned "seems I have clearance"...are you looking at upper clearance, from top of tire to wheel well clearance also? Depending on suspension travel/type, you may need 3"s at the top.
Jerry
OP:
Several web sites to compare tire sizes - width, diameter - in inches.
Then compare what you have -vs- size you are considering.
**Don't forget to verify the max tire pressure of your rims.
(Usually stamped on the back).
BTW - this is one of the times - a search & lots of reading of previous threads - is a good way to go.
About Fifth Wheel Group
