tkd01
Aug 09, 2017Explorer
tinner12002 wrote:
G You are correct that your tire height will only raise you RV 1/2 of the total tire height difference, just need to make sure your clearance on top or your tire is ok with the additional height of the new tires. In my opinion there's no such thing as over kill with the weight rating on a tire VS the weight of the RV as long as things don't get ridiculous. Using 3400lb rated tires on a 5K or 6K axle is the best safety way to go as long as your wheels are at least 6 lug and rated to handle the difference in tire pressures. Ride quality...not even an issue on an RV in my opinion and it probably will pull better too.
I totally agree with this: "THERE IS NO SUCH THING AS OVER KILL". I went with a G over an E rated tire at the recommendation of a trailer shop. Due to the small size difference, I had just 1" of clearance between the tires, and plenty on top. No problems. When you see the thickness and weight of the G rated tires, you will be impressed. If you have a blow out, which I had on my OEM China bombs, you will also tell yourself that there is no such thing as overkill. You don't need to keep the tires at 110psi. Look at load weight and base your psi accordingly. Since coming from an E rated tire the camper only requires 80psi max. I put close to 90psi and when hot they are 100psi. I have a 6 lug wheel and no problems what so ever. They are wearing even all around. So, in my opinion get the most tire you can that will fit and be confident going down the road.
About Fifth Wheel Group
