cuzbcuz wrote:
Campground host checked the volatage and it is between 108 & 112, which should be OK. We talked to a RV repair tech and he thinks that the washer/dryer might be causing the triped breaker. This is due to the load on the system during the hottest part of the day. He also suggested that we get the units serviced. I think that cleaning the condenser coils and general maintence would take care of the service issue.
108-112 volts sounds pretty marginal. Was the voltage checked during a high demand period? You may also want to check the female receptacle at the post. I'ts possible one of the pins is burned and may also be burning one of the pins in your plug. That's not too uncommon, in my experience.
If I noticed voltage that low I'd run other appliances (fridge & water heater)on LP rather than electric, as was suggested by another respondent. I'd also run the A/C unit temporarily on "fan only" (compressor off) when using the microwave.
