karmi's avatar
karmi
Adding a power inverter
I just recently realized quite by accident that in order to boondock with our RV, we will need to have a power inverter installed either by us or by a professional.
1. How difficult is it to install?
2. I have seen a lot of formulas for what size inverter we might need, but honestly, I still can't really make sense of it. What would you recommend? I would like to be able to use a toaster, hair dryer, watch TV sometimes, maybe a few other small appliances. Also, I guess how many batteries does the average rv need for boondocking?
3. I am disappointed and frustrated that we have been shopping for a new fifth wheel for quite a while and have told sales person that we have talked to that we are hoping to do some boondocking. Not a single one of them ever said, "did you know that you need a power inverter?" Can anyone think of anything else that we will need since salespeople don't seem to have a clue?
Thanks everyone for your input.
  • A hair dryer will eat up batteries pretty quick. Mine will draw over 100AH, which won't last long even with my 300AH battery bank.
    The battery bank size will depend on how long you want to go between charging.
    Salesmen probably know little about boondocking or your needs. Many people who boondock don't feel the need for 120V AC power without a generator.
    A 1500w continuous 2000w surge inverter should give you all the power you need. I have the xantrex x-power 1500 and it works very well. I have it wired thru a pair of xantrex inline transfer relays to power all of my general outlets.
    An auto transfer switch is a good idea so that you can power any outlet with the inverter, but shore or generator power will overrode the inverter. You won't want the microwave, a/c, fridge, or converter on the inverter circuit but the remaining circuits can be.
    At a minimum a pair of 6V batteries is what you want. If you use the inverter a lot you will need to recharge more often, or have 4 6V batteries installed... But they will take 2x as long to recharge from a 50% SOC.
  • You can get a 300 - 500 watt inverter for about $30 - $50, and plug it into a cigarette lighter receptacle.
    You can install a cigarette lighter receptacle near the TV set, or near your dinette table, or your bedroom nightstand, or all three. I ran #10 wire back and forth from the battery in one RV and from the fuse panel to the receptacle in another RV. What ever is closer, or easy to do. Put in a 30 amp fuse, and you are done.
    As for batteries, a pair of batteries will hold about 2,000 watts. This is plenty for most RV's. Your RV will use 35 amp hours per day just to run the refrigerator, CO meter, and propane detector. A average group 27 battery is 105 amp hours. Group 24 is about 85 amp hours. Golf cart batteries are 220 amp hours, but it takes two of them to make up 220 amp hours at 12 volts.
    Your TV set probably uses between 85 and 110 watts, or about 8-10 amp hours per hour. Cell chargers are much more efficient, with a plug in 120 volt one using about 0.5 amp hours per hour, while direct 12 volt one might be as little as 0.2 amps per hour.
    DVD player is about 20 watts, or about 1.5 amp hours per hour. It might be more efficient to use a computer, about 1.5 amp hours including the screen.
    Have fun boondocking! I always loved to find a forest service area, or campground over the private campgrounds that seem to be so crowded.
    Fred.
