Talisman61's avatar
Talisman61
Adding Inverter/Charger.Questions
Hi all,
Looking at getting a budget inverter/charger unit from Tripp Lite for my 71 caveman Truck Camper.
Currently my 110v and 12v systems are totally separate. I have shore power that feeds a single breaker, feeding my outlets/fridge/lights etc.
I have a Single 12v battery feed connected to my water pump and a few small 12v light fixtures.
Looking at this:
Tripp Lite APS750 Inverter / Charger 750W
And just wanted to clarify some things.
Using the above unit,
I planned to feed my 110v breaker box from one of the available outlets.
Hardwire shore power cable into the units AC input feed.
Run 2awg wire from this unit to my battery bank (adding a second battery in series)
Am i correct in assuming that when shore power is connected it will straight pass through this unit to my breaker and run everything as it does now while charging my battery.
When disconnected from shore my fridge will run off propane, not the converted 110v feed from my batteries.
I was looking at a simple converter/charger but felt the inverter/charger would suit my needs better. Since I have to add one or the other to charge my battery bank from shore power, I would like to be able to use my outlets when disconnected from shore if i ever have to.
New to camper configurations, not necessarily wiring and electrical.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
