time2roll
Jun 27, 2017Nomad
Not that I know of. Certainly get more amps to 90+ percent when you are at a higher voltage. Get 20 to 30 amps per battery and you will be fine. If you lose 15 amps it will not be noticed compared to dropping to 13.6 volts.
I assume needing a fast charge on generator. If you are plugged in for an extended period the PD, IOTA and Boondocker are all fine.
Going slower is fine too but most posts are about speed and low cost.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
