MTPockets1
Jun 02, 2014Explorer
Jim & Betty wrote:
Motorcycle jack
Thank You for the reply but the assumption about the Brandon address is not correct as I do not own any property in SD but I do stay there and do return there. The Brandon address is where I first landed when I came into SD and at this time Minnehaha County is my county of residence.
I guess the question should be does the Mail Service you use in SD use PMB numbers? That seems to be the big issue. In your case you had something that showed an apartment number and that seemed to work. However AR out of Sioux Falls says the Apt instead of the PMB is frowned on by the post office.
JimR
You are correct regarding use of Apt in place of PMB. We have used a mail service in Florida for two years. We have a PMB and the physical address of the mail service which is on our driver's license, bank statements, Credit cards. We have had no issues whatsoever with investments, banking, Concealed carry permit, etc... When we applied for the voter registration card, the voter registrar used the courthouse address in our PMB city as our voting address. I can't tell you why, but it's what they did and seems to work.
About Full Time RVers
1,589 PostsLatest Activity: Mar 30, 2026
