Andonso's avatar
Andonso
Aluminum water tank
I have a friend who purchased some property where he and has wife are living in a 5th wheel.
Currently there's no water or electricity. They're using a generator to maintain house batteries and for AC appliances.
We installed a 250 gallon plastic sewer holding tank for black water that on a sewer service that periodically empties when full. His 5th wheel black water tank is 38 gallon is periodically emptied into the 250 gallons tank that has sewer service when it becomes full.
There was electrical service at one time on the property which as soon as the service box is inspected and oked for service will connect up the outdoor 110 service box on a pole to the pud.
The current problem is with the city water system is charging a $10,000 fee to connect to city water, along a road next to the property. AFAWK there no well on the property. To dig a well has been roughly estimated to be $11,000 or possibly higher.
In the mean time we've been looking around for a water solution as there's no bulk water service in our area. We are thinking of installing large water tank ~250 - 500 gallons that can be filled from smaller 50-60 gallon tanks from a pickup.
We found a used 550 gallon plastic water tank, that was sold before we were able to contact the seller.
Then we came across another used 350 gallon tank, the only problem is it's made from aluminum. Seller described can be used for water, however I've been reading that aluminum water tanks, even though installed on boats, etc. that plastic food grade tanks are preferred as water holding tanks.
Some people have stated they've used aluminum water tanks for 15 to 25 plus years without any problems, while others have stated concerns about aluminum used for water storage. Problems such as aluminum getting into drinking water and reacting with chlorine, etc.
I'm uncertain if any source water such as from well or city water would have any chlorine.
Anyway I was looking for any feedback using aluminum tanks to store water which likely would only be used for washing dishes, taking showers, washing clothes and for a toilet. Currently water is coming from those 5 gallon jugs filled from water machine at a local store.
What concerns are there when using aluminum holding tanks to store water to be fed into a RV's main water tank which in this 5th wheel is 50 gallons (plastic water tank).?
A water holding tank is only a temporary solution until we figure how to connect to the city water for less than $10k. We're going to consult with the city water to see if they have some sort of time payment where payment towards the $10,000 fee would part of a monthly bill.
From what I've been told, since the city upgraded their water system that comes from wells pumped into large cement holding tanks they increased their connection fee. So it's possible they will lessen the connection fee sometime in the future.
  • Most if not all 'city' water sources are chlorinated, and tested! If you drill a well the water may not be drinkable, no guarantees. Check with neighbors and then a drilling company.
  • It may be more cost effective to have 5 fifty gallon drums and use the drums as your water tanks. Avoid the whole mess of shopping for the one massive tank. Use a couple more drums to take I'm the pickup to fill.
    If this won't work I'd pass on the aluminum tank unless it's an amazing deal or you think you'll have the city water within a few years.
    Proper plastic tanks are definitely preferable to aluminum so long as they are out of the sun.
  • You don't say what state you live in but a friend of mine put a 250 gallon plastic tank on a trailer and it works great. I would not use a Aluminum tank unless the water came from a private well with no chemicals added.
    I don't see the fees going down. Maintenance, water testing, chemicals, wages, etc. will only increase in price over the years.
    If allowed by the city, I would spend a little more and drill a well.
    But, it depends on the average cost of water per month in your area.
    Look at all the options before making a decision.
