neschultz
Mar 25, 2019Explorer
We bought our used 2005 SunnyBrook Titan in Jan. It has been in the same spot since it was delivered new and is hard piped into the sewer. We are used to a clear fitting to see the flow and how clean things are and hate it. We plan to change it the next time we go to FL. Haven’t decided if it will be part hose yet or not. There’s also no way to disconnect it if I need to without cutting pipe. Seems I’d want something with a flex joint also. Just things you might want to think about if you hard pipe it.
The best hose we found is the Drainmaster or Waste Master Hose with a cam lock fitting connection. Expensive but well worth it for travel (no leaks, easy to connect, valve at campground end, etc)...we’ve had it on our last 3 RVs. Not sure if using it on a stationary setup is justified.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
