carl2591
Aug 06, 2015Explorer III
Chicat wrote:
We have a Verizon 15 gig plan with 3 smartphones a laptop and a tablet and use all of it every month with out streaming any movies or music. All devices have update only on wifi and no matter how bad the campground wifi is it will usually update the devices late at night. Other wifi sources are Target, most McDonalds, Staples and Office Depo-Max. I did find that after switching to Verizon that they charge usage at a much higher rate than Sprint. What I used to do with Sprint I used less than 6 gigs, to do the same on Verizon is at least 9 assuming the phones all use 2 each.
That interesting to know.
you suspect "datamandering"?.. or is verizon actually doling out a gig when they say they are, or is the amount less say 700K-800K vs 1 gig.. the difference you stated is quite a lot.
unless your usage unknowingly went up due to better quality of data signal.. questions with that for sure.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
