bjcarpetguy wrote:
We got the Hopper and Joey for our RV. The Sat Dish is mounted on a small frame
We sit it outside on ground. We had to get the Azmith, Skew and degrees from
a local dealer here in. Quartzsite. The biggest problem with Dish is it uses
3 sattelites. Once the the skew and Azimith are set they shouldn't change. Then it is a matter of linning up the dish with a compass or handheld GPS.
it can be frustrating but did it last night and it took about 30 minutes and
had it up and working fine. Good luck.
Ditto for DirectTV. I bought a used dish off craigslist with a triple LNB. I aim it manually, usually first try in about 10 minutes.
