AdvSeekers wrote:
dons2346 wrote:
In SD, all you have to do is go to the sheriffs office located in the county in which you are going to "reside" and apply.
But first, you will have to have proof that you have resided there for 30 days. No ifs, ands or buts, it is 30 days. Having a CCW from another states means nothing.
INFO
Thanks for the link! It appears that the process for obtaining a CCW in SD is a bit simpler than it was in KS. I will get the ball rolling on the application as soon as we are finalized with our new address.
YES you will need a SD address first
Then you will need to physically be in the SD County where your address is for a minimum of 30 days IMMEDIATELY PRIOR to applying for the temporary permit
Then within 5 days you will get the temporary permit
Then 7-10 days later you can go back to Sheriffs Office and get your CCW....valid for 5 yrs.
Roughly 45 days total time (30 days Prior plus 10-15 days after applying)
29 states have reciprocity with SD CCW
